Field 'online_resolution' doesn't have a default value XC 90 2004m vairo stiprintuvas. | AutoVikingai.lt - Volvo ir Saab - švediškų automobilių klubas ir forumas
XC 90 2004M VAIRO STIPRINTUVAS.
minducci
Parašyta 2013-06-21, 20:30
Miestas: kaunas
Pranešimai: 3
Įstojo: 2013-06-21
gal pasakys kokios spalvos skystis pilasi ant xc 90?
Volvo XC 90
Parašyta 2013-06-24, 12:04
EU automobiliams:
Power steer power steering fluid
The level should lie between the MIN and MAX marks.
Power steering fluid of type Pentosin CHF 11S or the like. Tamsiai žalias
Check the level at every service. It is not necessary to change the fluid.
USA automobiliams
The fluid level should always be between the MIN and MAX marks. Fluid type : ATF
Replace : No fluid change required
